Setting a 5ms delay for a redistributed route.
May 30th, 2008
Here is a question:
For example, in eigrp, you want to redistribute isis routes, you want to set the delay of those routes to 5ms; Cisco IOS only allows you to set that value in tens of ms.
Given this information, how will I set the redistributed route's delay to 5 ms?
Overall Rating: 5 (1 ratings)
mheusing Sat, 05/31/2008 - 03:31
The value is set in tens of microseconds. So 5 ms would be 500 x 10 usec.
router eigrp 65000
redistribute isis metric 1 500 1 1 1
where the 5 metric values are: bandwidth delay reliability loading mtu
Hope this helps! Please use the rating system.
Regards, Martin
