'Work Not Ready' - 'Work Ready' states in UCCE
May 30th, 2008
Hello all,
I've noticed that my Skill Group and Agent Skill Group dont show the real WorkNotReadyTimeToHalf and WorkReadyTimeToHalf data. The agents are constantly using these buttons on their desktops but all I see is a few seconds on the reports. I also track these events on Agent State Trace table so they do use these buttons very frequently.
Is there something that I forgot doing on configuration?
Thank you in advance
Abdulbaseer Mohammed Fri, 05/30/2008 - 21:53
  • Silver, 250 points or more
Not sure if I followed you completely. Is this happening on webview? or?
Bozzy2008 Sat, 05/31/2008 - 03:58
Both, since I checked the DB, I'm sure it's the same on Webview
Riccardo Bua Fri, 06/13/2008 - 09:00
  • Cisco Employee,
Might be CSCsa27237. What is your running ICM release? Did you try going for the latest SR already?
Riccardo
valueteam_ccs Fri, 06/13/2008 - 06:49
If the agents works whit multiples skills, an agent may be in workready state for a skill and worknotready for another.
Bozzy2008 Sat, 06/14/2008 - 13:23
Thank you all,
I opened a TAC case last week, I checked out the bug, I will try the workaround tomorrow. I really hope the workready-worknotready time is calculated in the overall Handle time. I just need custom reports then.
Will keep you updated.
Thank you
