ASA H.323 disconnecting after 2 hours
Answered Question
May 30th, 2008
ASA 8.0.2
h323 sessions are disconnecting after 2 hours. I have tried to fix this with the following...
timeout h323 0:00:00 h225 0:00:00
and
access-list h323_timeout extended permit tcp any any eq h323
class-map h323-timeout
description h323
match access-list h323_timeout
policy-map global_policy
class h323-timeout
set connection timeout tcp 0:00:00
Neither have worked. Any suggestions?
Overall Rating: 5 (2 ratings)
acomiskey Fri, 05/30/2008 - 12:21
No, I had to disable h323 inspection to get a polycom to work. Does this effect the ability to set a timeout?
Farrukh Haroon Fri, 05/30/2008 - 12:49
As you know H.323 is opening dynamic connections (which comprise of both UDP and TCP). I don't know much about the Polycom implementation tough. By disabling inspection, I don't know if the firewall will be able to correlate the various control/data flows that comprise a single call (TCP / UDP) and apply the appropriate timeout.
Farrukh
acomiskey Sun, 06/01/2008 - 16:41
Thanks for checking into that for me. I'll give the timeout xlate command a try.
