VPN issue
May 30th, 2008
I have a group of users set up for VPN they can connect into the network without any issue, but while connect with the VPN they cannot access the web. They are part of the same vpn pool as another group and that group doesn't have a problem, but they are using a different username and password. Need some help.
Farrukh Haroon Fri, 05/30/2008 - 13:18
  • Red, 2250 points or more
What is your split tunneling policy?
Farrukh
asmith252 Fri, 05/30/2008 - 13:29
Ah....ok I forgot to set the split tunneling policy when I was setting up the group. Problem solved.
Farrukh Haroon Fri, 05/30/2008 - 13:47
No problem, glad to hear your problem is solved now :)
