Unity design question
robert-knapp
I have a Unity install that was poorly designed. The Exchange message store and the Exchange Partner server are logically not very close to Unity. As a result users will occasionally get delays when checking messages over the phone.
We are planning to redesign the Unity/Exchange integration and change physical location of these servers however in the meanwhile what can I do to prioritize this traffic?
Has anyone done this before? Can I simply prioritize the traffic between Unity and the message store, or would I need to prioritize the traffic between Unity and the exchange partner server?
I guess I don't understand the traffic flow for streaming audio from the Exchange message store to the handset while users are listening to messages thru the phone.
espereir
Level 5
Level 5
Hi Robert,
Unity design guide says that a LAB connection is required between Unity and Exchange and that Unity and the partner Exchange must be on the same segment.
This document will help you with this task; check page 14 ;)
--> Network and Infrastructure Considerations:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/405/design/guide/network.pdf
Hope this helps!
