Help with configuration of PIM routing
rastodsidata
Hi all,
I am trying to configure multicast routing between two ME3400 switches. I have two questions:
1. what IP address in "ip pim rp-address a.b.c.d" sholud I use on switch that is directly connected to multicast source?
My configuration is:
client <-> switchB <-> switchA <-> multicast_source.
I would like to use L3 functionality and route multicast from switch A to switch B so that client can joing to the multicast using IGMP. RP-ADDRESS on switch B points to switch A. And what abou RP-ADDRESS of switch A?
2. Is it possible to simulate functionality of PIM and multicast routring on one switch? ( multicast source is incoming to switch on vlan 200, there is rp-address pointing to local VLAN 200 interface address, and client is connected on VLAN201 with igmp snooping on the vlan.
ivillegas
Level 6
Level 6
The IP address to be a PIM RP. Only one RP address can be used at a time within a PIM domain. For ip-address, enter the unicast address of the RP.
Use the following documents for more information:
http://www.cisco.com/en/US/docs/switches/metro/me3400/software/release/12.2_44_se/configuration/guide/swmcast.html
http://www.cisco.com/en/US/docs/ios/12_2/ip/configuration/guide/1cfmulti.html
