5.5.1-019 ??
May 30th, 2008
Our C 600 hasn't been updated in a while because of job reasons. So we updated to version 5.5.1 - 019 of Async OS on the 28th. We also use Whats Up Gold to monitor our network devices. After the update process, now the SMTP service on the Ironport is dropping out about every 15 seconds. Any ideas??
hpiguy_ironport Fri, 05/30/2008 - 18:38
Yes I understand that 6.1 is out. We choose to do one update at a time rather than a big string of updates. This way if a patch breaks something we know which one did the damage. Whereas the other way we would not be able to pin it down.
kluu_ironport Fri, 05/30/2008 - 18:03
You should contact Support if you're having intermittent email flow problems.
Also, the current release is AsyncOS 6.1.x, so you may want to upgrade to that.
