Cable HWIC Support
May 30th, 2008
I have just bought a 2811 Router. The current IOS is 12.4(13r). I am trying to get 2 HWIC-Cable-D-2 cards installed. The cards say they are not supported. I am guessing that I need to upgrade to 12.4(14)T to fix this. Is this correct? If so where would I find the IOS?
patfitzenberger Sat, 05/31/2008 - 08:35
Your right, But 12.4(14)T should have every thing that is in 12.4(11)T right?
thotsaphon Sat, 05/31/2008 - 09:28
  • Gold, 750 points or more
yes! That should fix something in 12.4(11)T. May introduce something new as well.;-)
Thot
