how to utilize two links on one interface from two ISP's.
May 30th, 2008
we having 2 links from two different ISP's on one 7206vxr interface
first link is 20mb and second link is 5mb
i want to utilize the two links to browse at a time
at present i am using only one link
interface GigabitEthernet0/2
description description connected to Internet Switch G 1/0/1
ip address 78.xx.xx.xx 255.255.xx.xx
duplex auto
speed 100
media-type rj45
negotiation auto
interface GigabitEthernet0/3
description Connection to BGP Router
no ip address
ip verify unicast reverse-path
duplex full
speed 100
media-type rj45
negotiation auto
interface GigabitEthernet0/3.200
description Connection to 5mb link ISP1
encapsulation dot1Q 255
ip address 212.xx.xx.xx 255.255.xx.xx
no snmp trap link-status
interface GigabitEthernet0/3.220
description Connection to 20mb link ISP2
encapsulation dot1Q 733
ip address 192.168.xx.xx 255.255.xx.xx
ip route 0.0.0.0 0.0.0.0 192.168.198.29
Please suggest me .
best regards,
thotsaphon Sat, 05/31/2008 - 03:14
  • Gold, 750 points or more
Hi Mohammed,
Are you connecting 2 ISP for accessing the internet?
I haven't seen any NAT commands here. Have you already nat somewhere? If that 's for the internet then you can use 2 ways for utilizing 2 links.
ip route 0.0.0.0 0.0.0.0 212.xx.xx.yy(Next-Hop)
This lets box to do load-sharing as such per-destination load-sharing.
But I would concern about this way because you are using unequal links.Box will do load-sharing for you. May be 5M-link will be used at full utilization while 20M-link be used a few bandwidth (may be).
You can use PBR to load-sharing which traffics you want.
http://www.cisco.com/en/US/products/ps6599/products_white_paper09186a00800a4409.shtml
http://www.cisco.com/en/US/docs/ios/12_0/qos/configuration/guide/qcpolicy.html
If you have already nat then you may separate the traffics by using protocols(http,https,smtp etc) instead of using source ip address to route them out the interface you want.
Hopes this helps
Thot
phswrestler125 Sun, 06/01/2008 - 19:22
Hi sorry to steal the thread. but i was just wondering isnt there a device call like Fat pipe or something like that , that combines links from different IP's.
how does that work??
phswrestler125 Mon, 06/02/2008 - 07:05
bump
PAUL TRIVINO Mon, 06/02/2008 - 07:18
  • Bronze, 100 points or more
One device I know of is a Radware Linkproof. I believe all models are Ethernet/FE/GE based, goes in between your ISP routers and your firewalls. You configure it for your ISP IP ranges, and (by default) it balances traffic between the links. It also works for incoming connections, by becoming the DNS server for inbound traffic.
Paul
