Site to Site VPN Tunnel (Trouble)
Answered Question
May 31st, 2008
Hi, I am trying to make tunnel between two sites and I have setup all configuration and check configuration multiple times but still not able to recognize the issue. when I execute the below commands:-
show crypto isakmp sa
Result of the command: "show crypto isakmp sa"
There are no isakmp sas
Anyone tell me what should I do??? Thanks!
Can anyone tell me
Correct Answer by husycisco about 8 years 10 months ago
Sure you can
Hi Ray
In Rwanda
no crypto map outside_map 1 match address outside_1_cryptomap
crypto map outside_map 1 match address outside_cryptomap_1
Try setting pre-shared-key to 1 in both ends untill you resolve the issue.
Try reloading firewalls in both ends.
If reload doesnt work, try using a different transform set for l2l ESP-3DES-MD5 for example. Dont forget to define isakmp policy for this in India.
Overall Rating: 5 (2 ratings)
There could be multiple issues - but the first thing I would check is - if you have defined the interesting traffic, you have to identify what traffic should pass over the VPN - this in turn will bring the VPN up.
If you have no isakmp sa's - you don't have an active VPN.
HTH.
ray_stone Sat, 05/31/2008 - 05:26
Hi, both firewall configuration are attached for your reference but when by using troubleshooting command it doesnt show IKE peer. Please review it and tell me where I am doing mistake. Thanks.
ray_stone Sat, 05/31/2008 - 08:23
Hi, can anyone respond as I need to make site to tunnel on priority basis. Thanks
ray_stone Sat, 05/31/2008 - 08:24
Correct Answer
husycisco Sat, 05/31/2008 - 09:19
  • Gold, 750 points or more
Hi Ray
In Rwanda
ray_stone Sat, 05/31/2008 - 19:48
Thanks, now the tunnel has been created. Can I change in the access list instead of following commands and change outside_cryptomap_1 to outside_1_cryptomap.
Correct Answer
husycisco Sun, 06/01/2008 - 07:00
Sure you can
