Upgrading PIX to ver.8
May 31st, 2008
Can someone confirm if the PIX can be upgraded to verson 8 or is this only available on the ASA models? If the PIX can be upgraded, what are the memory requirements? Thanks.
Overall Rating: 4 (1 ratings)
cisco24x7 Fri, 09/26/2008 - 05:37
There was a beta version of 7.x for Pix 506E.
Yes, I did install it on my Pix506.
Latest "supported" software for Pix 501 is
6.3(5)
suschoud Fri, 09/26/2008 - 05:41
It is 6.3.5.
If you are already running 6.3.5,then you can try interim releases came after 6.3.5.
If not,then avoid running interims.
Do rate if helpful.
Sushil
If you are already running 6.3.5 and facing issues,then you can try interim releases came after 6.3.5.
Do rate if helpful.
Sushil
