1760 CCME 4.1 FXS problem
May 31st, 2008
I'm trying to configure a VIC-2FXS on a Cisco 1760 running 12.4(15)T4 (CME 4.1) with an extention... After trawling the internet and the Cisco website i have found numerous articles referring to STCAPP... Problem is, if i do:
1760-CCME#config t
Enter configuration commands, one per line. End with CNTL/Z.
1760-CCME(config)#st?
stackmaker stacks standby state-machine
i only get the following options... =(
Did i miss something???
Any help would be greatly appreciated...
Thanks...
Alan.
Michael Owuor Sat, 05/31/2008 - 07:50
Hello Alan,
Feature Mode for SCCP FXS Ports IOS is not available in the 1760, since this feature was introduces after that series of router went into End-of-Sale. There is therefore no development or introduction of new features for this platform.
These links lists the different platforms on which the feature is available
http://www.cisco.com/en/US/docs/ios/12_4/12_4x/12_4_6xe/htfeatmd.html#wp1053143
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t2/ht1vg224.html#wp1310413
Hope this helps.
Michael.
amcom Sat, 05/31/2008 - 07:56
Hi Michael,
Thanks for that... Are you able to provide any links or config to get an FXS port to act as an extension???
Thanks...
Alan.
Paolo Bevilacqua Sun, 06/01/2008 - 04:33
FXS works pretty much like an extension, just configure a DP for it. If you need call transfer, search "h.450" here, for recommendation on how to set such script.
