interface vlan
May 31st, 2008
I have a PIX 525 and ASA5510 with version 8.0 ... with unrestricted license.
when i try to create interface vlan on any of the device, i have no option to do this.
ASA(config)interface?
configure mode commands/options: Ethernet IEEE 802.3 Redundant Redundant Interface <cr>
Anything i need to enable this feature?
Thank you gerard
JORGE RODRIGUEZ Sat, 05/31/2008 - 08:46
  • Green, 3000 points or more
To create virtual interface you have to do it with subinterfaces, in other words if you are trying comeup with more logical interfaces you have to use 802.1q trunk to whicever switch you are using and create your L2 vlans in the switch pertaining to each subinterface you create in the firewall and map your switchports accordinly to proper vlans.
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/intrface.html#wp1044006
Gerard Gacusan Sat, 05/31/2008 - 12:29
I'm trying to check the sample config below with vlan interfaces, looks different than in the documentation. There's no sub-interfaces specified ...
Primary Unit Configuration for Example 16
passwd g00fba11
enable password gen1u$
hostname Buster
asdm image disk0:/asdm.bin
boot system disk0:/image.bin
interface vlan 2
description Primary ISP interface
nameif outside
security-level 0
ip address 209.165.200.224 standby 209.165.200.225
backup interface vlan 4
no shutdown
interface vlan 1
nameif inside
security-level 100
no shutdown
interface vlan 3
nameif dmz
security-level 50
ip address 192.168.2.1 255.255.255.0
no shutdown
interface vlan 4
description Backup ISP interface
nameif backup-isp
security-level 0
ip address 209.168.202.128 standby 209.168.202.129
no shutdown
interface vlan 5
description LAN Failover Interface
interface ethernet 0/0
switchport access vlan 2
no shutdown
interface ethernet 0/1
switchport access vlan 4
no shutdown
interface ethernet 0/2
switchport access vlan 1
no shutdown
interface ethernet 0/3
switchport access vlan 3
no shutdown
interface ethernet 0/4
switchport access vlan 5
no shutdown
srue Sun, 06/01/2008 - 11:59
  • Blue, 1500 points or more
That is from an ASA5505 - vlan interfaces on the ASA series is only possible on the 5505. as a previous poster said, you need to use subinterfaces if you want more than the number of physical interfaces.
