IOS firewall & Nat port forwarding
Answered Question
May 31st, 2008
I have a 1811 connected to the internet with a cable modem and a dynamic IP. I'm looking to forward port 80 from the outside IP to an internal host for testing. I've used the SDM to setup the router but I haven't found a way to forward the port that I need done. I'm not necessarily set on using the SDM to do this, I just don't want to set it up so if I make a change that gets over written later by the SDM.
If anyone could that would be greatly appreciated.
Correct Answer by Farrukh Haroon about 8 years 12 months ago
How about:
ip nat inside source static tcp 192.168.1.1 80 interface serial 0 80
Or are you looking to combine this with a service like Dynamic DNS (and want to access the service remotely using the hostname)?
Farrukh
Overall Rating: 4.5 (2 ratings)
Correct Answer
Farrukh Haroon Sat, 05/31/2008 - 11:46
  • Red, 2250 points or more
How about:
Farrukh
nmooremvsc Sat, 05/31/2008 - 12:51
Well,
I tried that and it looks like the port is still closed.
sirdudesly Sat, 05/31/2008 - 19:11
you also need to open the port in the firewall, from memory SDM "claims" it will open the port if you use it to make a static nat translation (which is what port forwarding is)
nmooremvsc Sat, 05/31/2008 - 19:29
Yeah it helps when the firewall on the host is not stopping things too.
