Privilege Levels
May 31st, 2008
I set up a basic call center application inside of a CME box. This application also provides some statistics that the customer would like to view. The problem is that requires CLI access to view the information. As I would like to give them minimal access to the CLI, what would be the appropriate way to do this? It requires privileged mode to view these statistics.
Thanks in advance for help.
Overall Rating: 3 (3 ratings)
Farrukh Haroon Sat, 05/31/2008 - 22:26
  • Red, 2250 points or more
Hello, you can just bring down whatever command the customer needs to a lower level and then create a user account on the router (for that privilege level). Or a less secure method would be to create an 'enable' password for that level (lets say level 7) and give it to the customer.
Have a look at the following links:
http://articles.techrepublic.com.com/5100-10878_11-5659259.html
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t13/feature/guide/ftprienh.html#wp1027258
http://www.cisco.com/en/US/docs/ios/12_2/security/configuration/guide/scfpass.html
Farrukh
aciscolook Mon, 06/02/2008 - 11:59
Hmmm...This looks promising. I'll give it a try
