giving out DHCP
May 31st, 2008
With Wireless LAN Controller Module in 2800 router is it best practice to have it give out DHCP to APs, internal users, and guest users? Or can existing Windows DHCP server be used for any/all of those?
Overall Rating: 4.8 (3 ratings)
scottmac Sun, 06/01/2008 - 05:39
  • Green, 3000 points or more
For regular wireless traffic, the MS DHCP server works just fine.
The DHCP pools on the router are typically used for inbound remote connections.
Good Luck
Scott
Scott Fella Mon, 06/02/2008 - 03:25
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Like Scott mentioned, the MS DHCP server would work just fine. Depending how you have your guest setup, that is usually the only time I will use the WLC as a DHCP. Again, that is when I have a WLC used for guest access and anchored to a DMZ.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
