Cisco-3845 Router all E 1 controllers is going shutdown automatically
May 31st, 2008
Curreent IOS is flash:c3845-ipvoice-mz.124-15.T1.bin
all E1 controller is going shutdown automaticall one by one
I am using VWIC2-2MFT-T1/E1
faisal_ghaus Sun, 06/01/2008 - 02:34
Similar problem was faced by me to on E1 controllers were automatically shutting administratively .Its was a problem with the interface what you do is enable terminal monitoring you will find the error messages once you turn on the controller configure syslog on the router if you cannot enable terminal monitoring
U can also use command show controller you will seee unknow on the controller type
