Caller ID with fxo and Telluler
Jun 1st, 2008
Hi every body ..
I have a uc500 with bulit in fxo ,,. i have connect to the FXO 0/1/0 an Ericsson Fixed Wirless terminal ... the ericson work like this ( you put a GSM SIM card on it -your mobile SIM for example- then you connect it to fxo port with your CME extention) so when any one dial your mobile number you get it in your ip phone.
one thing the Ericsson terminal can be set to use a multi CLIP standards : like DTMF,Bellcore,V.23
in my debug i use Bellcore
I will post this files:
1- uc500 running configuration
2-debugg VPM signal
Please help me if you can
jsivulka Fri, 06/06/2008 - 06:19
FXO per definition can only receive caller-id, and FXS send it only. Check how your paging system expects to receive calling number, because it cannot be the caller-id method. Are you sure you are not using an FXS port ?
