scanning $subject for multiple occurrences of a character
kluu_ironport Mon, 06/02/2008 - 19:32
Can you clarify on what you mean by "character threshold greater than one in the subject header" ?
when you say mulitple occurrence of a character, do you mean a repeat like "testssss" where the "s" is repeating?
What is it about this subject, " this_is_a_hundred_percent_spam_header
" that you're trying to match?
I just wanted to know if it is possible to use the GUI to check for a character threshold greater than one in the subject header.
We are seeing subjects like: this_is_a_hundred_percent_spam_header
and would want to block this kind of messages.
Any idea?
thank you,
SergioC
aharkin11 Tue, 06/03/2008 - 14:43
I'm not sure how to do it, but I'm guessing he's looking to look through the subjects for a certain number of underscores.
jackytime_ironport Wed, 06/04/2008 - 11:33
I think regular expression can filter such subjects:
([a-zA-Z0-9]_){3,}
to match 3 or more occurrences of letter_.
Usually I put these rules in a dictionary badsubj, use message filter below:
badsubj: if subject-dictionary-match("badsubj", 1) {
quarantine ("Policy");
deliver();
