VPN client connection errors
Jun 1st, 2008
Hi we have a VPN 3020 and for some reason we get the following message when successfuly connect to the vpn concentrator, but we can no access any of our applications:
Cisco Systems VPN Client Version 5.0.03.0530
Copyright (C) 1998-2007 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 5.1.2600 Service Pack 2
Config file directory: C:\Program Files\Cisco Systems\VPN Client\
1 21:53:41.828 05/12/08 Sev=Warning/2 IKE/0xE300008D
Split-DNS requires Split Tunneling and a primary DNS server
2 21:54:41.828 05/12/08 Sev=Warning/3 IKE/0xE300002C
ISAKMP header invalid: Invalid version 5.0 found
3 21:54:41.828 05/12/08 Sev=Warning/3 IKE/0xE3000039
Received an invalid or malformed IKE packet: message id = 0x05B3E098
4 21:54:41.843 05/12/08 Sev=Warning/3 IKE/0xE300002C
ISAKMP header invalid: Invalid version 6.5 found
5 21:54:41.843 05/12/08 Sev=Warning/3 IKE/0xE3000039
Received an invalid or malformed IKE packet: message id = 0xBBA0DB25
6 21:54:41.843 05/12/08 Sev=Warning/3 IKE/0xE300002C
ISAKMP header invalid: Invalid version 4.1 found
7 21:54:41.843 05/12/08 Sev=Warning/3 IKE/0xE3000039
Received an invalid or malformed IKE packet: message id = 0x6DBEB827
8 21:54:41.843 05/12/08 Sev=Warning/3 IKE/0xE300002C
ISAKMP header invalid: Invalid version 12.15 found
9 21:54:41.843 05/12/08 Sev=Warning/3 IKE/0xE3000039
Received an invalid or malformed IKE packet: message id = 0xD3B3F364
10 21:54:41.843 05/12/08 Sev=Warning/3 IKE/0xE300002C
ISAKMP header invalid: Invalid version 10.13 found
11 21:54:41.843 05/12/08 Sev=Warning/3 IKE/0xE3000039
Received an invalid or malformed IKE packet: message id = 0x9FBD5312
12 21:54:41.906 05/12/08 Sev=Warning/3 IKE/0xE300002C
ISAKMP header invalid: Invalid version 14.3 found
13 21:54:41.906 05/12/08 Sev=Warning/3 IKE/0xE3000039
Received an invalid or malformed IKE packet: message id = 0x462E7CD0
14 21:54:41.906 05/12/08 Sev=Warning/3 IKE/0xE300002C
ISAKMP header invalid: Invalid version 12.2 found
15 21:54:41.906 05/12/08 Sev=Warning/3 IKE/0xE3000039
Received an invalid or malformed IKE packet: message id = 0x7DC880A2
16 21:54:41.906 05/12/08 Sev=Warning/3 IKE/0xE300002C
ISAKMP header invalid: Invalid version 12.11 found
17 21:54:41.906 05/12/08 Sev=Warning/3 IKE/0xE3000039
Received an invalid or malformed IKE packet: message id = 0x6C75C87A
18 21:54:41.906 05/12/08 Sev=Warning/3 IKE/0xE300002C
ISAKMP header invalid: Invalid version 12.0 found
19 21:54:41.906 05/12/08 Sev=Warning/3 IKE/0xE3000039
Received an invalid or malformed IKE packet: message id = 0x6D60C62E
20 21:54:41.906 05/12/08 Sev=Warning/3 IKE/0xE300002C
ISAKMP header invalid: Invalid version 8.10 found
21 21:54:41.906 05/12/08 Sev=Warning/3 IKE/0xE3000039
Received an invalid or malformed IKE packet: message id = 0x741149C0
22 21:54:41.906 05/12/08 Sev=Warning/3 IKE/0xE300002C
ISAKMP header invalid: Invalid version 12.13 found
23 21:54:41.906 05/12/08 Sev=Warning/3 IKE/0xE3000039
Received an invalid or malformed IKE packet: message id = 0x9F361006
24 21:54:41.906 05/12/08 Sev=Warning/3 IKE/0xE300002C
ISAKMP header invalid: Invalid version 4.3 found
Has anyone come across this problem when in a visitiros network with access to internet only and you are going out via a Checkpoint firewall with smartdefence. Using Cisco VPN client you are able to connect but get malformed packets dropped due to the length. Ceckpoint are saying this is a cisco problem has anyone else had these problems
owillins Fri, 06/06/2008 - 06:19
  • Silver, 250 points or more
Block IKE packets from rouge IP address on the GW router (before it reaches VPN 3020), if possible.
