h323 gateway, outbound calls need to select specific POTs line
Jun 1st, 2008
I have a customer with a centralized call manager running 4.3.1. At one remote location, they have two buildings, two different addresses, that are fiber connected. They have two pots lines connected to the router that is installed at one of the buildings. We would like 911 calls for building one to use line 1 and 911 calls for building two to use line 2. Can I do this with H323 or does the gateway need to be MGCP? If I can do this with H323, please provide a sample. Thanks.
dbenattou Sun, 06/01/2008 - 10:33
you can resolve this problem by selecting the source-address
for exemple
dial-peer voice 10 voip
transtion-profile incoming test
answer-address 5..(Directory Number for Building 1)
voice translation-rule 1
rule /\(^0\)/ /911\1/
voice translation-profile test
translate called 1
dial-peer voice 12 pots
destination-pattern 911T
port 0/0/0: 15(Access for Building 1)
i hope that it can helps
