ccme
sunnyverghese
How i can add the prefix to the below config for sending the sip cals to the other ccme
i need a prefix 6 and the number
dial-peer voice 800 voip
destination-pattern 9...
session protocol sipv2
session target ipv4:10.101.1.5
session transport tcp
dtmf-relay rtp-nte
codec g711ulaw
no vad
I am waiting for your valubale reply.
Thanks in advance
dbenattou
hello,
have you tried the prefix command into the dial-peer
I think that it must work for your case.
You could also use a translation profile:
voice-translation rule 101
rule 1 /^9\(.*\)/ /69\1/
voice translation-profile PREFIX6
translate called 101
translation-profile outgoing PREFIX6
