IDM Access after an Upgrade
Answered Question
Jun 1st, 2008
Hi, I recently upgraded my IDSM-2 from 5.0(2) to 6.0(4a)E1. But I could not access it over IDM. Has anyone ever encountered this issue before? I was wondering if I have missed something or I have to patch anything.
Thanks in advance.
regards,
Jonix
Correct Answer by Farrukh Haroon about 9 years 1 month ago
Maybe its something related to Java requirements changing between the releases. Do the following:
1) Try different browsers
2) Try Different PCs
3) Try using Java 1.5.x and not 1.6.x. Make sure you have it selected under IE >> Internet Options >> Advanced >> Java (Sun)
4) Try setting the Java Memory size -Xmx256m in the Control Panel Java.
Just in case also re-check the network-settings/ACLs in the service host / network settings. (But if these were not correct, telnet will not function also)
Farrukh
Overall Rating: 5 (1 ratings)
Correct Answer
Farrukh Haroon Sun, 06/01/2008 - 23:05
  • Red, 2250 points or more
Farrukh
