The WLCM & WLCM-E for the ISR do not support the below:-
- Servie Port
- 1000Base-T modules
- VPN Termination
- QoS per-user bandwidth contract
- Layer 2 LWAPP
- Spanning Tree
- Port Mirroring
- AppleTalk
- Layer 3 security polocies not supported - for VPN termination
Everything else a 44xx can do, the WLCM & WLCM-E can.
HTH.
markgrinceri Mon, 06/02/2008 - 18:44
Hi, Thanks for that Information, do you know about the aironet 1252?? As I can only see reference to 1240
Scott Fella Mon, 06/02/2008 - 18:49
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
What exactly are you looking for?
Here is a link to the 1252's:
http://www.cisco.com/en/US/products/ps6973/index.html
markgrinceri Mon, 06/02/2008 - 19:01
I have search that site already looking to see if the 1252 support HREAP without luck, do you know if they do support it?
Rob Huffman Tue, 06/03/2008 - 04:27
  • Hall of Fame,
    Founding Member
    2017 IP Telephony, Unified Communications
Hi Mark,
Here is a note to add to the great help from Scott and Andrew. These are the latest H-REAP requirements;
Requirements
H-REAP is only supported on the 1130AG, 1240AG and **1250 access points and on the Cisco 2000, 2100 and 4400 Series Unified Controllers, the Catalyst 3750G Integrated Wireless LAN Controller Switch, the Cisco WiSM, and the **Controller Network Module for Integrated Services Routers.
From this excellent doc;
H-Reap Design and Deployment Guide
http://www.cisco.com/en/US/products/ps6521/products_tech_note09186a0080736123.shtml
Hope this helps!
Rob
