Trunk capacity
Jun 1st, 2008
Was curious to know, how to determine the trunk capacity of a switch ? Is there any cisco recommendation for this.
Amit Singh Sun, 06/01/2008 - 23:25
Trunk capacity??? It depends on the type of ports you have in terms of bandwidth capacity. It depends on switch model numbers in terms on supports vlans to be carrid over the trunk links. Like some of the switches support 4K vlans, some 1K vlans, some 256 vlans.. etc...
-amit singh
Sushil Kumar Katre Sun, 06/01/2008 - 23:35
If you want to know if the interface on the siwtch supports trunk and which encapsulation mode use -
show interface capabilities
Switch# show interfaces gigabitethernet0/2 capabilities
Model: WS-C3560-24PS
Type: 10/100/1000BaseTX
Speed: 10,100,1000,auto
Duplex: full,auto
Trunk encap. type: 802.1Q,ISL
Trunk mode: on,off,desirable,nonegotiate
Channel: yes
Broadcast suppression: percentage(0-100)
Flowcontrol: rx-(off,on,desired),tx-(none)
Fast Start: yes
QoS scheduling: rx-(not configurable on per port basis),tx-(4q2t)
CoS rewrite: yes
ToS rewrite: yes
UDLD: yes
Inline power: no
SPAN: source/destination
PortSecure: yes
Dot1x: yes
-> Sushil
