CallManager and PSTN access
Jun 1st, 2008
Hi all,
I have one router which is configured as MGCP and where i have two connections for the PSTN : 1 PRi and Two BRI but i'm asking if i can use the BRI as a bachup i mean the preference 0 would be the E1 and the preference 1 would be the BRI for outband call thanks for replying.
note: i was thinking to add the router twice where each one i only include the erquired card and then in the route group i just divide one for E1 and the second for the BRI
Thanks for ur advise
Seifeddine-Tlili Tue, 06/03/2008 - 04:35
hey everyone,
Let just rephrase my purpose
So i have one gateway that have one PRI connection to the PSTN and TWO BRI and i want to use my Voice gateway for outband calls using the PRI and in case of failure or busy signal switch to the BRI on the same router so can anyone tell how can i do that with Route Group?
I'm waiting for any advises :) thanks
