ASA 5580 Load balancing between server
Jun 2nd, 2008
I have an ASA 5580 and i would like to khnow if this Firewall do a load balancing between server ( Round-Robin, Weighted Round-Robin, Fail-over chaining) . If no what is the equipement that i must add to perform this task.
Thank you very match for your help
Houichi Nizar
tj.mitchell Mon, 06/02/2008 - 05:30
The ASA won't load-balance servers as a load-balancer will. To get that functionality you should probably take a look at the ACE appliance or ACE module. That will give you server load-balancing along with quite a few additional features.
HTH..
pls rate if this helps.
