How does HSRP works
kgabo
Hello there!
Please S.O.S.
We have on our campus two 6509 connected together with a Gig link running hsrp.
Master 10.1.16.4 Standby client 10.1.16.5 and vertual and default gateway for hosts 10.1.16.1
I have a filling hsrp is no longer working.
Problem 1. When i create a vlan on the master it does not get copied to the standby as was before.
Problem 2. Now i can configure vlans on any switch on the network standby or any other client switch which was not posible before. Initially i could add vlans from the master switch only and they get sychronized to standby and others.
There seems to be no sych between master and stanby switches or HSRP is not functining completely.
see data below.
Master
IOS ver.
IOS (tm) c6sup2_rp Software (c6sup2_rp-PK2SV-M), Version 12.1(19)E1, EARLY DEPLO
YMENT RELEASE SOFTWARE (fc2)
interface Vlan1
ip address 10.1.28.4 255.255.240.0 secondary
ip address 168.167.60.1 255.255.252.0 secondary
ip address 10.1.16.4 255.255.240.0
ip helper-address 10.6.1.21
no ip redirects
no logging event link-status
standby ip 10.1.28.1
standby priority 110
standby preempt
standby 1 ip 10.1.16.1
standby 1 priority 110
standby 1 preempt
standby 2 ip 168.167.60.4
standby 2 priority 110
standby 2 preempt
GAB-ML-IT-1-RS-01-6509# sh vtp status
VTP Version : 2
Configuration Revision : 104
Maximum VLANs supported locally : 1005
Number of existing VLANs : 34
VTP Operating Mode : Server
VTP Domain Name : BTC-HO
VTP Pruning Mode : Disabled
VTP V2 Mode : Enabled
VTP Traps Generation : Enabled
MD5 digest : 0x18 0x72 0x26 0xFD 0x97 0x1C 0x84 0x02
Configuration last modified by 10.1.16.4 at 6-2-08 07:13:44
Local updater ID is 10.1.16.4 on interface Vl1 (lowest numbered VLAN interface f
ound)
STANDBY
IOS ver.
interface Vlan1
ip address 10.1.28.5 255.255.240.0 secondary
ip address 168.167.60.5 255.255.252.0 secondary
ip address 168.167.60.2 255.255.252.0 secondary
ip address 10.1.16.5 255.255.240.0
no ip redirects
GAB-ES-CR-G-RS-01-6509# sh vtp status
VTP Version : 2
VTP Operating Mode : Client
What might be the problem here, plz help???
ebanks2006
At a glance, your VTP domains are synchronized - looking good from the output you displayed. The "master" (VTP server mode) is at revision 104. The "standby" (VTP client mode) is also at revision 104. Both switches have 34 VLANs.
VLAN creation and propagation to other switches has nothing to do with HSRP. VTP handles that duty using trunk links. A place to start looking is to verify that your trunks are up and working with "show interface trunk".
royalblues
Level 10
Level 10
HSRP does not carry VTP information and is not responsible for vlan propagation.
Have you enabled VTP password in your server switch by any chnace and not on others?
Also from your output i see that you have VTP version 2 enabled. so Make sure all your switches are running VTP version 2
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/vtp.html#wp1029449
Narayan
ebanks2006
raj_ctech1103
Try the following thing,it will sure work for ur environment--
1-First thing both the master and standby core switch should be in vtp mode-server.All other client switch will be in client mode.
2- Configure the same vtp domain and password for all the core and client swicthes using following command--
vtp domain
vtp password
above two steps will solve ur vlan replication problem.
3-Better will be if u create different vlan for what u have assigned secondary ip in interface vlan 1.
Revert back the status .
regards,
Raj Kumar
