Locking IP Phone with Key combination
Jun 2nd, 2008
Is there any key combination on a cisco IP Phone that can be used to lock an IP Phone? If no, is there any way one can lock an IP Phone to prevent it being used by another person?
iptuser55 Mon, 06/02/2008 - 02:34
It depends on what you wish to do and why. If it is to block all calls except say internal
Create a CSS and assign it to the phone which block every call except internal and inform your users of Extension Mobility and let them over ride the previous CSS -internal only by logging on .
FAC codes- depending on the CCM level - FAC is used for external calls or calls via Route Patterns, again internal calls are OK byut to make an external call they need to enter a FAC- - FAC tend to be a single code which you give to lots of people
Zin.Karzazi Mon, 06/02/2008 - 05:44
I dont know about the coasts, but we have it running for 3years now without problems. There is a contact section on the website of andtek so you can ask them about the price.
End of sale is about the server version not the product itself.
