H.323 and MGCP configuration on the same VG
Jun 2nd, 2008
I have a 3845 voice gateway that connects to both PBX and PSTN via 4 E1 ports (2 for the PBX & 2 for the PSTN). Is it possible to configure the 2 pri ports connecting to the pbx as mgcp gw and the 2 pri ports connecting to the pstn as H.323 gw?
Do you see any issue with this implementation?
The ccm version is 6.1
Thanks in advance.
Chris Deren Mon, 06/02/2008 - 05:13
This is absolutely OK as long as you dont control the same port with both protocols. I've done this several times without issues.
