IPSec tunnel between site to site
Jun 2nd, 2008
I have PIX515E configured and working fine.It has the Site-Site IPSec (Main site A to Site B and Site A to Site C)configuration and it is working fine also.Now the customer want another Site - Site IPSec between site A to site D.
When I create this IPsec site - site configuration,the previous Site to site IP sec tullec is getting disabled.
Can any of you help me to configure Main site to multiple site IP Sec tunnel.
Thanks and Regards,
S.Venkataraman.
tj.mitchell Mon, 06/02/2008 - 08:49
  • Bronze, 100 points or more
Sounds like you are using two different crypto maps. Then enabling the new crypto map on the outside interface, thus disabling the existing tunnels.
Please post the configs, but this is what is sounds likes you are doing.
HTH..
pls rate if this is helpful
Fernando_Meza Thu, 06/05/2008 - 02:26
  • Gold, 750 points or more
Hi ...
assuming that your internal network is 172.16.30.0 and the other site is named Remote-Site .. then the below configuration should get your third tunnel working.
** Traffic to be tunneled
access-list crypto_map_60 extended permit ip 172.16.30.0 255.255.255.0 Remote-Site 255.255.255.0
** Bypassed NAT for traffic to be tunneled
access-list inside_nat0_outbound_1 extended permit ip 172.16.30.0 255.255.255.0 Remote-Site 255.255.255.0
tunnel-group xxx.xxx.xxx.xxx type ipsec-l2l where xxx.xxx.xxx.xxx (the IP address of the other VPN termination Device)
tunnel-group xxx.xxx.xxx.xxx ipsec-attributes
pre-shared-key your-key <- same on other site
***** isakmp phase 1 ******
crypto isakmp policy 60
authentication pre-share
encryption 3des <- same on other site
hash md5 <- same on other site
group 2 <- same on other site
lifetime 7200 <- same on other site
***** isakmp phase 2 *****
crypto map outside_map 60 match address crypto_map_60
crypto map outside_map 60 set peer xxx.xxx.xxx.xxx <-IP address of the other VPN termination device
crypto map outside_map 60 set transform-set ESP-3DES-MD5 <- same on other site
You might need to re-apply the crypto map again ..
**** re-apply the crypto map to the outside interface
no crypto map outside_map interface outside
NOTE: is it VERY IMPORTANT that The remote device have the same parameters for phase 1 and 2. the same pre-shared key, the same traffic to be tunneled.
hope it helps .. please rate it if it does
