default gateway for switch management
Jun 2nd, 2008
Hi all, on my 3550 switch, I have several vlans, for the default gateway for management I have set this as the ip address of one of the vlan interfaces, is this correct ?
bvsnarayana03 Mon, 06/02/2008 - 04:15
  • Silver, 250 points or more
Yes this is correct. On L2 switches you can have only 1 active management VLAn interface, while on L3 there can be many.
carl_townshend Mon, 06/02/2008 - 04:30
hi there, so could i set the default gateway as any of the vlan interface ip addresses ?
srue Mon, 06/02/2008 - 04:34
  • Blue, 1500 points or more
are you using your 3550 as a layer 2 or layer 3 switch? ie is the "ip routing" command enabled? if so, it's layer three, and your default route (not default gateway) takes priority.
Now, if yo'ure talking about setting the default gateway on each of the hosts in each vlan as the respective vlan interface, then yes, that's how you would normally enable inter-vlan routing in this situation.
