access point document
Jun 2nd, 2008
we need to place a access point on floor. For 1 Mbps it works for 450 feet. Now walls are constructed with Mi-one tech.
I need a document from which i can get information about strength of signal or obstacals that might degrade signals
please guide us
Overall Rating: 5 (1 ratings)
rob.huffman Mon, 06/02/2008 - 04:48
Hi Pushpak,
Signal attenuation or signal loss occurs even as the signal passes through air. The loss of signal strength is more pronounced as the signal passes through different objects. A transmit power of 20 mW is equivalent to 13 dBm. Therefore, if the transmitted power at the entry point of a plasterboard wall is at 13 dBm, the signal strength will be reduced to 10 dBm when exiting that wall.Here some examples;
Plasterboard wall Signal Attenuation 3 dB
Glass wall with metal frame Signal Attenuation 6 dB
Cinder block wall Signal Attenuation 4 dB
Office window Signal Attenuation 3 dB
Metal door Signal Attenuation 6 dB
Metal door in brick wall Signal Attenuation 12 dB
Human body Signal Attenuation 3 dB
From this good site survey doc;
Hope this helps!
