VPN 3020 concentrator Error 8
Jun 2nd, 2008
Hi, I got a customer how get the following message: ERROR:-- Config file could not be written, error 8, it look like there is something wrong with the flash. Is anybody wath the error code reference to and is thre a way to retreive the running-configuration or save it out of the box. It look to me like we only can save it to flash before being abble to export it from the box.
Richard Burts Mon, 06/02/2008 - 10:14
I recently had an experience with a customer where we had difficulty in doing a save in the web management interface. We went to the console interface and in its menu system asked it to save the config. And it worked. I am not sure if it will work for you but it would be worth a try.
lomenard Mon, 06/02/2008 - 11:43
Hi Rick
Thanks for replying, the screen snapshot I received was from a telnet session, i don't thing that will be different through console port, but we have nothing do loose to give a try.
