Upgrading from 3.5 to 5.0
Answered Question
Jun 2nd, 2008
Looking for info on moving to 5.0 UCCX from IPCC 3.5. We've already built the 5.0 server and are beginning the config. I didn't see any migration tools. Rebuilding ports/tapi config shouldn't be a problem. Can I use scripts from 3.5 as is? Any guidance would be appreciated.
Brian
Correct Answer by Chris Deren about 9 years 3 weeks ago
There are no migration from UCCX 3.5 to 5.0, only from UCCX 4.5 to 5.0.
The scrips will work fine, however I suggest you open each and every one of them on new editor and save them into the repository as some steps get converted.
HTH, please rate all helpful posts!
Chris
Overall Rating: 5 (1 ratings)
Correct Answer
Chris Deren Mon, 06/02/2008 - 12:24
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Chris
