Adrian Saavedra Mon, 06/02/2008 - 09:54
  • Gold, 750 points or more
Hi friend,
You can use the CFwdAll softkey in IP Phones.
If you are using CallManager, this can be achieve by configuring the CallForward All property in the phone extension page.
In CallManager Express it is achieve with the call-forward all command under ephone-dn.
- adrián.
cfajardo1_2 Tue, 06/03/2008 - 07:19
"You can use the CFwdAll softkey in IP Phones" --when will we use this...
Justin Brenton Tue, 06/03/2008 - 07:22
  • Silver, 250 points or more
Hi cfajardo,
Press CFwdAll softkey on your phone, then press 22222, #.
Are you using a digit to get a secondary dialtone to the pstn? if so you may need to place a 8,9 in front of the 22222. i.e. 922222.
You can also change this in the web based administration pages.
Hope this helps,
Please rate,
Justin
donovan222 Tue, 06/03/2008 - 07:45
Is there a way to have both phones ring at the same time? So I could pick up the call on the IP Phone or the cell?
Rob Huffman Wed, 06/04/2008 - 05:06
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hey Cleso,
Hope all is well :) Here is a little added info to go along with the great tips from Adrian and Justin;
If you want to Set up call forwarding on your primary line
Press CFwdALL or Forward All and enter a target phone number (in your example the mobile number. So Outside access 9 then 2222222).
Cancel call forwarding on your primary line when you want to take calls on the desk phone again.
Press CFwdALL (This takes the phone off of Call Forward All)
To Verify that call forwarding is enabled on your primary line
Look for:
• The call forward icon above the primary phone number: .
• The call forwarding target number in the status line.
From this good doc/user guide (Look at Page 33);
http://www.cisco.com/en/US/docs/voice_ip_comm/cuipph/7961g_7961g-ge_7941g_7941g-ge/6_0/english/user/guide/ug6141.pdf
Look under "Start Here" for Forwarding Calls in this nice e-learning tutorial :)
http://www.cisco.com/comm/applications/CCNP/qlm/7961/index.htm
Hope this helps!
Rob
