Jun 2nd, 2008
Hello I need to know if UCCX can work o inteconnect with DB postgrest.
anyone can help me?
htarra Fri, 06/06/2008 - 06:21
Yes you can. Based on the information available, UCCX 5.0(2) only supports "Windows
Authentication" mode but I believe that was the case even with 4.0(1)
also. Can you confirm you are trying to use the windows authentication
and if so what are the credentials (username / password) being used ?.
If you are trying to create a system DSN but failing to authenticate,
you can try creating the DSN while logged in as Administrator / password
which matched UCCX Admin account.
Also do you have MSDE or SQL server running on the UCCX server ?. You
might be able to look at DB users via SQL Enterprise manager if you have
SQL server running.
Maic Naatz Fri, 10/28/2011 - 01:55
Yes, you can configure an ODBC Connection on Windows based UCCX. Download and install the ODBC-Driver within Windows.
Download URL for the current driver:
I testet that on UCCX 7.1.3 SR01 and PostgreSQL 8.4.7
But keep in mind, you cannot migrate this configuration to UCCX 8.x. Look: https://supportforums.cisco.com/thread/2112624
