WAE 612 Log
Jun 2nd, 2008
Has anyone seen this message before??
Jun 2 07:37:44 Site-WAE-1 tcpproxy: %WAAS-RE-3-690422: (548714) conn-id: 5784671: RE Aggregation error: process_full_tree failed -1105 (Read failed: not found)
The message is not in the alarm book for version 4.0.17.b.14....should I be concerned?
Overall Rating: 5 (1 ratings)
dstolt Mon, 06/02/2008 - 13:05
Mike,
This message deals with a particular connection-id (5784671) and DRE aggregation information. I don't think you need to be concerned unless you start seeing this a lot in the syslogs.
Dan
mike-greene Mon, 06/02/2008 - 13:16
Thanks Dan,
I see about ten or fifteen a day starting at the beginning of April. Would that be considered a lot?
Mike
dstolt Mon, 06/02/2008 - 16:28
I don't think so. If it was coupled with poor performance and was happening currently it would be something we could look at in the DRE aggregation stats.
Dan
