Break out digit translation pattern?
Jun 2nd, 2008
We are running CallManager 4.1(3). We would like to bring up some addtional sites and assign them each a partition. Then create a translation pattern to require a breakout digit to dial between the partitions.
If this translatino pattern isn't matched it should go look at a route pattern.
Is this possible?
Does anyone have a good way of doing this?
This is how we would like to setup the dial plan:
8=breakout digit
xx = location code
yyy = extension
8xxyyy
Any ideas?
