WPA2 error
Jun 2nd, 2008
I am trying to create a WLAN with WPA2 and AES for our WVoIP through WCS. Every time I try to apply the template to the controllers I receive the following error: "WPA2 Security Not Supported in this controller version". WCS is version 5.0.89 and the controllers are 4.2.99. Has anyone seen this before?
Thank you,
Scott Fella Mon, 06/02/2008 - 19:17
Might be due to your WCS being on version 5 and your WLC being on version 4.2. I know some say that WCS 5 is compatible with 4.2, it might be but some templates might not work like in your case. I was always told by TAC to keep the same version level. But I might be wrong....
Trending Topics - Security & Network
