gogasca Mon, 06/02/2008 - 18:19
  • Green, 3000 points or more
Oh boy, 5.0.4.1000-1 is not the best version to run with a customer, glad to hear you are upgrading...I really recommend going for at least 5.1(3)latest ES or 6.x which are pretty decent versions
Please take a look at;
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/rel_notes/5_0_4/504ccmrn.html
could you please post the install logs.
How many servers?
Server model
Upgrade method, SFTP, DVD?
fopravil Tue, 06/03/2008 - 04:21
thanks for interest.
I am not quite sure I understand the "release note": does the paragraph "Upgrade During Install Fails" say that I shoud do 5.0(4a) upgrade first?
My customer has only one server, unfortunately; type HP DL320-G4, 2.8GHz processor.
First time I attempted to upgrade from DVD, and I have got the following error message:
System Error. Please verify the MD5 hash value against the Cisco Systems web site: 9e:38:b8:fe:9a:e7:c1:26:30:52:e1:fc:6c:28:47:32
But the MD5 hash has been correct; possibly the upgrade program has ejected the DVD too soon?
So I used FTP to do the upgrade. The upgrade lasted about 1/2 hour, when I have got the following messages:
Current Version: 5.0.4.1000-1
Upgrade Version: 5.0.4.4000-1
You have requested to upgrade the machine with version: 5.0.4.4000-1
A backup is highly recommended before proceeding.
File cisco-ipt-k9-patch5.0.4.4000-1.tar.gz
Start Time Mon Jun 02 15:06:14 CEST 2008
Status Failed. Please review the log.
Please find the log from upgrade installation in enclosed file Cucm5.0.4cUpg.txt.
Can I use the "cisco-ipt-k9-patch5.0.4.2000-1.tar.gz" to do the upgrade? It is not signed, the CUCM 5.0.4 upgrade will not accept it?
Or can I upgrade directly to cisco-ipt-k9-patch5.1.3.3000-5.tar.gz.sgn?
fopravil Tue, 06/03/2008 - 04:56
Sorry,
one more question. CUCM 5.1(3.2104.1) Engineering Special is half the size of CUCM 5.1(3b) patch. Is it missing anything?
Regards F. Opravil
