Calls go right to Unity VM
Answered Question
Jun 2nd, 2008
hi,
I have a user who calls go right into vm after a dial by extension through AA.
I am running ccm 4.1.3 and unity 4.2.1
Randall
Correct Answer by Jaime Valencia about 8 years 9 months ago
check under the subscriber transfer options that you have it set to "yes, ring subscriber extension" and not send directly to VM
javalenc
if this helps, please rate
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Mon, 06/02/2008 - 13:52
  • Cisco Employee,
  • Hall of Fame,
    2011
javalenc
rcrumm_2 Mon, 06/02/2008 - 13:59
Yes!
That was it!
Thanks for the assistance.
Randall
