Quick NAT Question
Answered Question
Jun 2nd, 2008
  • Blue, 1500 points or more
I dont have a lab right now to lab it up, so I need some expertise...
with the statement
ip nat inside source static network 10.0.0.0 3.0.0.0/24
any address on the 10.0.0.0 network will get NATed to an address on the 3.0.0.0 network, correct?
But how are the 3.0.0.0 address allocated? In numerical order?
Victor
Correct Answer by Richard Burts about 8 years 12 months ago
Victor
In NAT using the static and network combination the host bits of the source address are mapped directly to the bits of the translated address. So if you had address 10.22.33.44 it would be translated into 3.22.33.44.
Rick
Overall Rating: 5 (2 ratings)
Correct Answer
Richard Burts Mon, 06/02/2008 - 17:42
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Victor
Rick
lamav Mon, 06/02/2008 - 18:01
O, OK..
So, its just a one for one then...
So, you would really use this when you want to make a sweeping NAT of an entire network, right?
VL
Richard Burts Mon, 06/02/2008 - 18:07
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Victor
right
Rick
lamav Mon, 06/02/2008 - 18:23
OK, thanks, Rick. Appreciate the sanity check.
Have a great night.
Victor
