Handling MARS's "System Rule: Misc. Attacks: TCP/IP Protocol Anomaly"
Jun 2nd, 2008
i have a IPS 4260 monitoring 4 inline links, connecting to a MARS 20.
MARS having been reporting a large amount of TCP related alerts over WAN; ie:
-TCP packet with segment out of order,
-TCP packet out of state order,
-TCP segment out of window,
-TCP Packet With Bad Checksum
Can anyone advice on the best practise or how should i assess and handle these situation?
mhellman Tue, 06/03/2008 - 13:25
Even if you decide to continue to alert on this sigantures, I would recommend creating a drop rule with "log to db only" for these alarms. They occur too often in "normal" traffic for them to be useful.
ben.gordon Sun, 06/22/2008 - 17:20
Sounds like a problem with the ISP. They may have a congested backbone or a faulty piece of equipment causing the errors. I would check the configuration of the links and interface errors.
