06-02-2008 06:05 PM - edited 03-18-2019 09:02 PM
Event Source PerfDisk event id 2001 warnings are flooding my Unity system app log every other second. Is there a way to stop these messages? I know there is a way to enable and disable perfmon warnings but not sure if that would work in this scenario as well? Any suggestions?
06-02-2008 07:05 PM
Nick!
Long time no see :-) How are you?
Try run the following command from a command (DOS) prompt:
perdisk -y
See also;
http://support.microsoft.com/default.aspx?scid=kb;en-us;296187
Michael
06-02-2008 07:45 PM
Hi Michael:
How are you? Its been ages since we last spoke. Hope all is well with you. Thanks for the tip and do keep in touch.
Nick
