HSRP config
jaweed123
How can I add the HSRP config to a VLAN interface option.
6 Replies 6
Amit Singh
This is how you could do it :
Interface Vlan 10
ip add x.x.x.x y.y.y.y
standby 1 ip x.x.x.x
standby 1 preempt
standby 1 priority 150
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_35_se/configuration/guide/swhsrp.html
HTH,
-amit singh
bvsnarayana03
Level 5
Level 5
interface Vlan5
ip address x.x.x.x 255.255.252.0
standby priority 60
standby 1 ip y.y.y.y
standby 1 priority 60
standby 1 preempt
x.x.x.x = physical Ip on interface
y.y.y.y = Virtual Ip (used as gateway for hsots on vlan)
Priority = Higher priority switch is active
Preempt = Causes the switch to takeover the active state when its priority is higher than other switch.
Thanks ... I will try it should work.
Hi Narayan,
The default priority value is 100 and why did you choose the 60 as priority, why not 5 or 100 or 200 or 500 ?
Thanks and Regards
I think the other poster choose the priority 60 in order to make this router as a standby and the other as active.If u leave the priority for default u will not have the control over election of standby and active routers.
Mahmood
Thanks Mahmood.
