CVP and VXML Gateway
Jun 2nd, 2008
Dear Sir,
I would like to enquire about the CVP 4.0 Server Software (CVP-4.0-Server-SW) and CV 4X Report System - Standard (CVP-4X-RPT-STD), we are going to implement a pig IPCC Enterprise project but we faced with the following points:
• The product Authorization Keys are not active for the CVP-4.0-Server-SW (4 PAK) but we founded them ( with the CVP-4X-RPT-STD product Authorization Key, as you can find below:
Product SKU Option SKU Description Quantity
CVP-4X-RPT-STD CVP 4X Report System - Standard 1
CVP-4.0-SERVER-SW CVP 4.0 Server Software 4
• Also we have AS535XM-VXML (VXML Gateway) and we need to know how we can check the Voice License Per Port (FR535XM-ENHVOXLIC).
Thanks in Advance
Islam Irshaid
geoff@hp.com Thu, 06/05/2008 - 07:41
  • Red, 2250 points or more
When you ordered your 5350 it would have been as (for example, top of the line) AS535XM-VXML-240-V and would have included FR535XM-ENHVOXLIC (AS5350XM IOS Enhanced Voice License Per Port) for 240 ports. This is a VXML only gateway with no PRIs.
Are you saying you've forgotten/misplaced what you ordered and want to log into the gateway and issue a command that will tell you how many ports you are licenced for? Are you asking which "show" command will tell you?
Geoff
islam.irshaid Sat, 06/07/2008 - 21:50
Thanks to you
yes i need to know the command,,, and if you can help me with the first need
