Phones display Blank
Jun 2nd, 2008
hi to all...
My 7961G display was blank. i unplugged the cable and plugged again. it works...why it happend? im using ccm 4.2 phones Load is sccp41-8-2-2SR1S
Thanks in advance
Nahas
Adrian Saavedra Tue, 06/03/2008 - 22:24
  • Gold, 750 points or more
Hi friend,
It is possible you're hitting something similar to bug CSCsb56074:
UI screen is grayed out when i-button is pressed
Symptom:
Conditions:
1.Goto Settings button-->Status Press on i-button.
2.Try to press 3 or 4 times.
3.Soktkeys become inactive and UI screen is blank.
Workaround:
Press the i-button twice more to bring up the real help screen. Then exit the help text.
Can you try doing the test on purpose?
- adrián
Nahassamad_2 Tue, 06/03/2008 - 22:42
Thank you for your reply..
The phone is working now. I tried this but no effect.
Nahas
