wireless controller image corrupted
Jun 2nd, 2008
HI all,
My wireless 526 controller is corrputed and now i am not able to load the image.
any one can advise on how to reload the image ?
i only see the below from console
thanks
grub>
Possible commands are: blocklist boot bootp cat chainloader cmp color configfi
le debug dhcp displayapm displaymem embed find fstest geometry halt help hide i
fconfig impsprobe initrd install ioprobe kernel lock makeactive map md5crypt mo
dule modulenounzip pager partnew parttype password pause rarp read reboot root
rootnoverify savedefault serial setkey setup terminal terminfo testload testvbe
tftpserver unhide uppermem vbeprobe
Rob Huffman Tue, 06/03/2008 - 05:07
Hi Chee,
It would be best to open a TAC Case for this. For other WLC Models this is a fatal error;
CSCsd52483
Controller stuck at grub> prompt
Symptom:
A WLC2006, WLC2106 or NM-AIR-WLC6 may seen to display a "grub>" prompt on the console port. It will be unable to boot the
WLC software and will not be able to operate normally.
Workaround:
Replace the hardware.
Hope this helps! And best of luck.
Rob
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
