route maps
Jun 3rd, 2008
hi,
anyone knows why policy routing to a next hop ip address is not supported in asa ? will it be soon ? (i can only use route map with ospf metrics, there is no ip next hop command)
Thank you
Syed Iftekhar Ahmed Thu, 06/05/2008 - 10:08
  • Blue, 1500 points or more
Route-maps on ASA are only for redistributing ospf routes between ospf processes. PBR as we see in IOS is not available in ASA.
Syed
Richard Burts Sun, 06/08/2008 - 18:15
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Joseph
I believe that Syed is on the right track with his response. A router is a device that does mostly routing and some firewall functions. An ASA is a device that does nostly firewall functions and some routing.
Policy Based Routing with route maps is a routing function. To get that routing function you need a router. I doubt that the ASA will go so far in its routing function to ever support PBR.
Rick
khwajanusrat Thu, 02/14/2013 - 05:04
Thanks for your input. I have a problem.
ASA -----link1 ------ASA2
        -----link2 ------ASA2
My ASA has two interfaces/links to ASA2 at site B. I want to route particular traffic on each link. How can I do that?
Jouni Forss Thu, 02/14/2013 - 07:44
Whoa,
A pretty old thread this one.
To my understanding ASAs are getting PBR feature in one of the future updates to the software.
I would wait until that feature becomes available. Otherwise I would leave PBR for actual routers and keep the firewall configurations as simple as possible.
I guess there are some tricks you can do with NAT but I have never really gone deep into such setup (other than to simply test it briefly)
- Jouni
